Gimbal Gyroscope Error
Cross posted - sorry.
So my son, who will have this taken out of his butt later, decided to throw a nerf football at a friends drone. Well, maybe he should be a QB someday, but on that day it got him into trouble because he knocked the drone out of the sky. The thing was pretty beat up - camera completely broke off and a propeller broke. Being somewhat handy I took it upon myself to try and repair the drone.
The repairs included replacing the propellers and the ribbon cable in the camera and gimbal unit. This video shows almost exactly the same camera system repairs (though it is a slightly different model):
After getting the drone put back together I boot it up and the camera stays stationary/limp. There is video feed and everything else seems to work fine, but the camera motors dont move it at all, in any direction. I can hear a slight buzzing sound from the motor that keeps the camera horizontal, if I move it then the buzzing gets a little louder. In the app the status shows "gimbal gyroscope error" and "Hardware Malfunction. Contact support for repair" (or something very similar). The gimbal calibration does nothing.
Can someone please point me in the right direction for repairing this at the lowest possible cost? I don't have money for this but I feel obligated to get it fixed. Any help is greatly appreciated and I will answer any questions that may help someone more knowledgable to narrow in on the cause and part that needs replacement.
Note that I have done this twice now, with a second ribbon cable, with exactly the same result.
Thanks in advance!
Having similar issue with gimbal after being repaired. Receiving Hardware Malfunction error, gimbal roll and tilt error. I have not checked the roll sensor.....where is it located on the phantom 3 pro?
Thank you
Thank you
Right on top of the roll motor.
Sent from my SM-G935V using PhantomPilots mobile app
All I get is a gimbal gyroscope error no tilt or roll error. Gimbal doesn' move at all but has the same buzzing noise and when I move it gets louder as well
Yeah, when your gyroscope doesn't work properly, motors will not move at all - gyroscope is needed to compute their positions.
EDIT: <removed false statements>
I stand corrected. Gyroscope is on this board, near the central hole:
WM321 Gimbal top board · mefistotelis/phantom-firmware-tools Wiki · GitHub
The specific chip is most likely: MLX90316 Triaxis rotary position sensor.
Hola. Se produjo el error "Gimbal Gyroscope Error" en dos Phantom 3 Standard. Probé 4 flex no originales y ninguno funcionó en ninguno de los dos drones. Luego compré 2 flex originales dji y ambos drones funcionaron. Como profesional técnico de drones recomiendo usar solo flex originales dji. No compren flex no originales.
Saludos desde Rosario, Argentina. mauriciocruzdrones.com
Reactions: Droneted
Hi. The "Gimbal Gyroscope Error" error occurred in two Phantom 3 Standard. I tried 4 non-original flexes and neither worked on either of the two drones. Then I bought 2 original flex dji and both drones worked. As a drone technical professional I recommend using only original flex dji. Do not buy non-original flex.
Greetings from Rosario, Argentina. mauriciocruzdrones.com
I totally agree. I have been down this road many times. Mauricruzesdrones is absolutely correct. Save a lot of time and effort and get OEM cables if they are available
The Gyro For the Camera is in the Camera, on the
M160A 15191 607AA
1​
MAX21100 6-axis MEMS digital gyro + accelerometer
Board.... That also has the CMOS and MEMORY Card Holder..... There are 2 Boards inside the Camera, The Chip Number above has all the Stuff to Make the Camera Work, the Other Board does all the Magic with the Video Signals....
Reactions: quaddamage
[QUOTE = "mauricio11111, publicación: 1452769, miembro: 108943"]
Hola. Se produjo el error "Gimbal Gyroscope Error" en dos Phantom 3 Standard. Probé 4 flex no originales y ninguno funcionó en ninguno de los dos drones. Luego compré 2 flex originales dji y ambos drones funcionanon. Como profesional técnico de drones recomiendo usar solo flex originales dji. No compren flex no originales.
[/ CITAR]
Hago una actualización al mensaje sobre los flex. Investigando me di cuenta que el problema de los flex no tiene nada que ver con ser o no originales, sino con el número que está escrito en el flex. Hay varios flex para un mismo modelo de drone, por ejemplo, el Phantom 3 Standard tien uno que termina en .06, otro .04 y otro .07. Hay que poner el flex correcto para que funcione bien. Hay algunos flex que funcionan en varios drones, y otros que no.
Soy mauriciocruzdrones.com
Saludos cordiales.
M160A 15191 607AA
1​
Es correcto, el giroscopio está en la cámara, no en la plaqueta principal del gimbal. Por eso cuando el cable flex funciona mal muestra error de giroscopio. También sucede si se instala un cable flex que no corresponde.
Saludos cordiales.
[/ CITAR]
Saludos cordiales.
Hola Mauricio.
Mi cable termina en .07 y no puedo encontrar uno por ninguna parte, solo para los modelos SE. El mio es un Standard. Sabes que cable puedo usar de los que dices que funcionan en varios?
Hola Mauricio.
Mi cable termina en .07 y no puedo encontrar uno por ninguna parte, solo para los modelos SE. El mio es un Standard. ¿Sabes que cable puedo usar de los que dices que funcionan en varios?
Hola buenas noches, yo compre 2 flex para mi SE y me sigue apareciendo el error "Gimbal Gyroscope". Leyendo estos comentarios entiendo que no es el correcto. Ambos terminan en .07, los compre en AliExpress, la calidad es excelente, igual al original, por si aun no lo encuentras.
Ahora te quiero preguntar, ¿Qué número aparece en el flex para SE? Ya no tengo el mío original y nunca vi el numero para poder conseguir el adecuado.
De antemano gracias, y gracias a todos por sus comentarios.
intertronixlabel
