Gimbal clamp redux?
Discussion in 'Pro/Adv Discussion' started by Chuck Young, Nov 1, 2015.
  1. Chuck Young
    Given there are new products coming out all the time for the P3P and the fact I need a new gimbal clamp, What is your favorite clamp?
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I like the OEM gimbal lock. It works well when installed properly.
  3. Chuck Young
    It is OK but have had it come off in transit. In fact when I received my phantom from the factory the gimbal clamp was rolling around in the box.
  4. droneshop
    Calgary, AB
    That's the lazy factory. When I have installed it properly it has never budged
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Unless yours is not made properly (not likely), it would not be possible for it to fall off if you install it like in the video below. The key is to squeeze it onto the gimbal yaw arm when you have it lined up. The harder you squeeze, the tougher it'll be to remove.
  6. Drone_on
    Twin Cities, MN
Similar Threads - Gimbal clamp redux Forum Date
In need of an urgent DIY Gimbal Clamp Phantom 2 Vision + Help Jun 29, 2017
P4P Gimbal Clamp with ND Filters? Phantom 4 Pro Help Mar 22, 2017
P4P with new Polar Pro ND filters - Gimbal Clamp Fix Phantom 4 Discussion Jan 29, 2017
Polar Pro "vivid" series filters - gimbal clamp does not fit - ARGH! Phantom 4 Pro Discussion Jan 21, 2017
New Phantom 4 Pro came without the gimbal clamp. Phantom 4 Pro Discussion Jan 14, 2017
