Gimbal ajustment
Hi,
on my second flight, just noticed tha my gimbal, when in up position is tilted slightly up, not at a strait 45 degree angle. Aslo not pointing directly to gound whe in down position. Verry minimal but I am wondering if it is correct. Had a verry small crash and everything is in order. Never noticed before. Gimbal is working fine. Trid calibration and it is still the same. No ajustments possible.
Called DJI, spent 45 on hold, and the tech said the on normal position, it should be 50degree, slightly tilted upward.
Is it normal or my gimbal is not correct
Thanks for the infos
Check that the mounting bracket is not bent, I suspect it happened in the crash.
Split the two parts and rotate 180 degrees, then put it back and see what you get.
Thanks,
Kev
intertronixlabel
