GoPro hero 3+ black pearl screen/ iosd mini with plug play cable and fat shark RX 5g8 250 mW .
Can not get a video on screen getting pissed off now any answers please
Ribbon cable that plugs into the go pro more than likely torn , replace it and you should be good , just happened to me...
Thanks for the info will try this and see what happens.OK GOOD NEWS IS IT WORKED and have the monitor doing as it should. Off to do 1st flight with FPV Jason thanks for the head up I spent a wasted 8hrs trying to sort it out yesterday the air was very blue and grand kids got to learn some new words lol.Have you updated the firmware on your GoPro camera lately?? If you have that cameras video out from the USB port has been shut off.and the only way to correct the problem is to rollback the firmware. If you are sure and this was a used camera the minute you turn the camera on the present firmware is list at the very bottom of the screen and it's only there for couple of seconds. Corrupted firmware is 03.00 and you need to rollback to 02.00 using the following link. If unsure on how to do this go to GoPro's update page and read or printout the instructions and follow those to the letter.
Drivers filed under: GoPro HERO3+ Camera Firmware
Also delete the the old update from you download file if you download the 03.00 firmware.
the only way to correct the problem is to rollback the firmware. If unsure on how to do this go to GoPro's update page and read or printout the instructions and follow those to the letter.
I've had a look on GoPros website and all I can find is a big warning saying the planet will implode and wipeout every living thing........!
Please can you post the link or paste the instructions here.
Another workaround (if you don't want to risk certain death etc etc) is to disconnect the GoPro USB from the gimbal, power up the Phantom AND GoPro and start recording, then reinsert the USB. The camera will stay recording with video out, and charge the battery at the same time. It's just a fiddly faff reinserting the USB whilst fighting the gimbal etc.
I have a Phantom 2 w/ Zenmuse h3-3d, GoPro hero 3 silver, AVL58, iOSD mini, and Bluetooth Datalink. Also using a Blackpearl Monitor. After updating the GoPro firmware to 3.x all video transmission ceased. The AVL58 was transmitting and the Blackpearl was getting the iOSD data but nothing from the GoPro. I replaced the USB ribbon on the Zenmuse, no change, replaced the tx module of the AVL58, no change. Then I found and purchased a connector for the Zenmuse that replaces the USB ribbon with one that connects to the slot on the back of the GoPro and now everything works as it should. The connector can be found on eBay for about $10. Fairly easy to install. Not saying this will fix anyone else's problems, just putting it out there....
