Black Pearl monitor has a lot of fans but I always found it a bit tedious. For those that are still not in FPV or those researching monitors, have a look at this:
Look at the results... and then look at the price tags for these 2 monitors...
Before comparing monitors in the sun turn around and face the sun and you'll find they both work very well. Another thing when checking the distance of both monitors to see which performs better it would be a good idea if the quads antenna were facing you instead of away as you were doing in that test.
Fact is none of the 5.8 Ghz monitors work well when the sun is shining right on them even with a sun hood.
Thanks for your reply witold, can I trouble you more and ask where can I get theses antennas, and do they have a part number or anything like that...?
Thanks Waylander
Thanks Waylander
