FPV don't work
I was filming, everything was perfect, then I turn off the P2V+, and then when turn it on, I can't see on my tablet what the camera see, but I can take pictures and video, I can see all the flight parameter (longitude, altitude...) but the FPV don't work... I need help!
That is a pretty common problem. The wifi module in the phantom has probably burned up on you. You can try checking the ribbon cable but its usually a couple hundred dollar fix for the onboard module. There are allot of unhappy people having to replace it. I would like to get hold of a burned up unit and see what needs repair inside it. If you replace it I would be happy to buy the old one off you or try to repair it free of charge.
Jeremy James
https://www.facebook.com/USdronerepair
You mean the wifi module on the Remote Control, the white little box ? because, that one is working perfect, or you mean about a circuit board inside the phantom?
Yep that's the one. I would be very interested in the old burned out one to disect and repair.
Question for you guys:
Why if the wifi module is burned up, I can see on my tablet: latitude, longitude, distance, I can move up and down the camera, etc.... ? The only thing I can't see is video, the all other functions work perfect
Old Gazer said:
I have to ask. Have you been using the booster app? It seems the app may be over heating the module.
You are the first person I've heard say that . I think that's BS
viewtopic.php?t=27447#p252506
I don't think you or anybody else knows the long term effect of changing the way the wifi extender was designed to work.
src72
