FPV Booster App DOUBLE Vision+ FPV Range
Re: Vision+ Wi-Fi Booster DOUBLE FPV Range
I have to say, it worked great on my galaxy S4 last night...I put some video 2 pages back..
Broke my old record today. New distance to beat is 6,245
Only upgrade 8dbi antenna on Wi-Fi box. 5,384 was my lonest flight at this location before upgrade
Surprisingly on the way back I turned on the booster app and went back out. I only got 5,126 before rth was activated. I was at 44% battery on the drone though. I guess that could be why. I'm still using the lowest resolution for max distance. I'll test different resolutions soon. I want to start with a fresh battery and the booster on and see what distance I get. As crazy as it sounds I think I'm losing line of sight that's why rth is being activated. Otherwise I could keep going. But yesterday where I was in endless farmland I couldn't beat 6,029 with the booster. An inconsistent foundation is frustrating to establish a pattern with
Re: V+ Booster Longest FPV Range Contest
Smb said:
Smb said:
So the problem it's specifically with the Nexus5?
EDIT: no, the problem ISN'T specifically with the Nexus5. If you google "dji 640x480 android preview" you can find several testimonials. Also on google play: "640x480@30fps FPV does not work on any of my android"
If you read my instruction carefully, I indicated "2. Preview quality should be set to 640x480 15fps."
Hit 2,600 ft distance, 500ft alt. in NAZA mode today.
DBS said:
I don't know.... plenty of people are reporting the problem so must be a number of devices... i guess you could make the opposite assumption that it isn't specifically related to Android 4.4
This is a well known issue of the VISION app with 640x480 30fps preview quality. That's why I stated "2. Preview quality should be set to 640x480 15fps." in the contest instruction.
Smb said:
Android DJI app on Android 4.4 dont work at this resolution.
He was specifically responding to that post and that preview quality... that's why I kind of argued the point a little bit... at 15fps there are still people having problems though.
I hope to get out and do a test on my P2V+ tomorrow morning with the Android booster App.
Just out of curiosity, how do you guys get the 640 x 480 15fps to stream smoothly, for the life of me it won't on my
Galaxy S3, the only one that streams smoothly is 320 x 240 15fps.
D
D
i cant get 640x480 30fps to work past 100 feet or for more than 15 seconds at a time.
640x480 15fps is slightly less annoying but just as frustrating. tomorrow i'll test both of them and idk what i'll get with the booster, but i bet i'll get less than 700 feet without it.
D
For smooth video streaming 640x480@15fps, there are mainly 2 factors to consider.
1. Wifi network - If you get smooth video when P2V+ aircraft nearby and glitch at distance, then it's likely network issue.
2. Vision app & device - If you get glitch video even P2V+ nearby, then it's likely Vision app or device (Galaxy S3) issue. You may try different version of Vision app 1.0.39 or 1.0.40 with 640x480@15fps in case any incompatibility issue. You may also check how many background apps running on your S3 and stop/kill those unnecessary apps, which may use plenty of processing power.
640x480 is not working at all, on my nexus5.
I've got the iOS app, running at 640x480 @30 I'm getting smooth FPV right out beyond what my 5.8 Antenna can achieve. In fact I haven't lost video feed once since I downloaded the app a couple of weeks ago. So well done all round :D
I'm using a Horizon 12 dbi dual Antenna 2.4 and 5.8. The 2.4 is performing well out to 4500 ft ,but the 5.8 is letting the side down and until I can improve the 5.8 I can't see just what this WiFi booster will do.
Quick Android beta udpate: I have about 6 flights in with the wifi booster, and everything has been working as expected with no issues. Due to bad weather, I haven't been able to do many distance flights, and the couple I did do were not as good as my first distance test both with and without the booster on. I'm guessing the weather has played a big role in my decreased distances.
PVFlyer said:
I have updated your record in the beta summary. Did you use 640x480@15fps preview quality? If not, can you further test the FPV range at 640@15fps?
Yes I did.
Humidity would definitely affect RF propagation on both 2.4G and 5.8G.
Hovtech said:
Yes I did.
Can you post a screen capture to show such Distance, and I can then put you to the FPV range contest.
That would explain it. It has been really humid, and I noticed both 2.4G and 5.8G had substantial decreases than what I was used to. In fact, sometimes the 5.8G signal would be lost while I still had 2.4G, so that is probably a good testament to the wifi booster app :)
Glad to know the booster app keep your FPV the highest resolution.
Your 5.8G 12 dBi helix has only 9 dBi effective gain (-3 dBi loss) when matching with vertical polarized antenna on the aircraft, unless you mod the aircraft to 5.8G CP antenna.
Scav8tor
