Thank you. I purchased a cheap vrConversion from 2D to 3D is not worth watching, if your Goggles has 2D mode, watch movie on that. It will give less strains to eyes then.
If you have HDMI interface, you would need an Apple adapter to convert USB to HDMI to connect and play videos.
Thanks! I have tried this vr viewer with the drone, and where it is great in bright sunlight, its only usable when high to avoid running into something. It seems to me that the glasses is the way to go, so you can look over the top of them when needed. What do you think?Conversion from 2D to 3D is not worth watching, if your Goggles has 2D mode, watch movie on that. It will give less strains to eyes then.
Do the glasses you use plug into the usb port on the controller?All this is good if you have clear flying area or you are flying a mission (waypoints). I use glasses as I can easily see both
