No, the Google map is blank...Is there a fix for it?
its cause the editted apk. Just install with a non-editted apk and then edit the json files and maps will be fine and you wont get the update prompt.
Video lag is terrible for me too with 3.1.3. Are you using a samsung galaxy s7 ? As regards the process to get rid of the update window, I too have to apply regulalry the process again that consists in modifying the 2 files (list.json and component_upgrade_list.json). After that, open Dji go, you'll have same message again, close and try again and it will work.I don't mind so much about here maps, but the video lag is terrible in 3.1.3
Yes galaxy s7..Video lag is terrible for me too with 3.1.3. Are you using a samsung galaxy s7 ? As regards the process to get rid of the update window, I too have to apply regulalry the process again that consists in modifying the 2 files (list.json and component_upgrade_list.json). After that, open Dji go, you'll have same message again, close and try again and it will work.
HI All - I"m trying to document all of the methods to fix this issue in a Google doc. Its open for editing if anyone wants to contribute, I'm just compiling it and have done my best to give credit to those who posted the ideas. Please feel free to edit it up!
How to: Fixing the forced upgrade in DJI Go for Android
There is where I found this guide to changing these two files..Tommi
If you read post 1 you should be ok.
If I open the Go App and it advises I have to update, I simply close the app then edit the list.json file, then delete the asdklog_s file.
Then open Go App again. if it still tells you that you have to upgrade, simply close and reopen. Most of the time it will then allow you to select "remind me later". It has never asked me a second time on the same day.
I am on a tablet and "closing" may be a bit different on a phone. You have to stop the Go app, not put it in the background.
You do have to open the app first then change the file and delete the other. A bit of a mess around but I can still use the version I want. I put up with this as I do not want to use root access.
These two steps are just part of my flight prep. As well as setting airplane mode, ensuring gps is on & wifi has connected, then starting mobizen on the tablet...
Not sure where you got the info referring to component_upgrade_list_.json file.. You do not need to touch it.
How to: Fixing the forced upgrade in DJI Go for AndroidSo before every flight you need to re edit the json file to keep using older version of dji go?
Is it possible to do it once and forever, without rooting my shield?
I tried step 4. It didnt work. But thanks for this list. I downloaded pre ready apk file from there, installed it. It asked me to update i said remind later, and thats it. It didn't appear since. I think this will be permanent fix!How to: Fixing the forced upgrade in DJI Go for Android
Follow method #4. I did this 2 weeks ago and haven't been prompted since.
Is anyone else being prompted days after who followed the steps for method 4?
For those who are wanting Google maps etc. and increased function - and the choice of when to update / use etc. - why not take easy route and install Litchi ?
Umm .. i havent seen that. I'm on 2.9.1 and the update prompt hasnt come back since. I would close DJI and re-copy the files, see if it takes. What device??Just tryed #3, worked great all day on 3.0.1, untill i shut down tablet, next day back to wanting to update, what went wrong
