FLYTREX problem - SOLVED
When i load the data from my Flytrex Core 2 onto Flytrex.com it shows my starting altitude at 1000ft instead of 0ft.
So if i fly up 100ft it shows 1100ft.
How can i fix this? Anyone else have this issue?
are you looking at your altitude above sea level, or your altitude above ground. I'm 300ft above sea so thought it was reading wrong
Altitude above ground. Where does it track sea level altitude.
I only see one altitude. It should read 0 when you turn on the phantom. Mine reads 1000.
You are right Fandango. I was looking at above sea level. I feel stupid.
i feel for the same mistake at first, the one labelled "ascent" is your height from ground
