Flying from inside house or car anyone?
Side note,
Since it seems like to 300C RC deals with video quality better on these newer apps i decided to compare the USB boards. Are they different ? Do they work different. Something is different.
Top board = 300C. Bottom = 300A. Completely different...
What I am thinking, is if I rename the apk to current rev. #, will it think it's current?
Johhny, I'm afraid that is considered TOP secret. You'll need to see the commanding officer to get clearance. (Laughs)..Moment.
Not sure that will work.
2 list Jon folders need modified. I'll find the link or screen shoot mine.
Some were changing the permission from 1 to 0 and renaming the app in this listjon folder. Didn't work for me. Once I removed all info between the brackets it worked.
Reactions: JohnnyB
Here's the mounting bracket. I had cut the plastic sheet before I bought a circular skill saw blade. The new blade works great!! But I ddn't see a reason to re cut the sheet so far. Prbly will as I now am looking at it being kinda crooked...
Reactions: JohnnyB
Darn, I had hoped 6.0 would run Go4. Wonder if I went back 1 more.
2.9.1 is working good on 7.0. I had better stick with it.. a quick edit of 2 folders will keep it from updating for a week or 2...
I just had to reconfigure mine before I could use it yesterday. Not sure how that happened. Changed them to read only after change... Hmmm
You might be able to access fastboot on the K-1 to reset it to 6.0 or what ever back up the hidden restore has in disk.
Reactions: Turbomania
Your file path
Android/data/dji.pilot/cache/list.json and component upgrade list.json.
Both need to look like this when done, open in a text editer.
{"application":
"announcement":
Lot more code......
You are basicy removing all the text between the 2 brackets that are now together...
Woooh
Reactions: JohnnyB
Your file path
{"application":
"announcement":
Lot more code......
Woooh
But it only works for a while? Or perm?
Mine was about 4 days then the update returned. I tried Go 4, but it sucks. Gonna go back to 2.9.1 again. I can remove that text within the K1 in just a couple minutes. I would rather do that than use Go 4.
What Johnny said.
Mine lasted a few weeks.
It's easy to edit..
If your handy with Firewalls there is an update folder that can be blocked also.
It's worth it. Much better video stream..
Reactions: JohnnyB
My RC updated without asking. I guess when I opened Go 4. Need to roll'er back.
Your file path
{"application":
"announcement":
Lot more code......
Woooh
Let me guess.... it needs root doesn't it?...
