Just reading your post... Sorry to hear about flyaway... Just giving some thought to the whole GPS errors... Now I'm an airline pilot and we use some pretty fancy GPS avionics for navigation ( don't claim to know the ins and out of how its work exactly, been flying for 20 years ). However when we shoot approaches we used to have to check for what was called "RAIM" with the old GPS systems. New ones do it for us now
.... And if it's doesn't that what first officers are for
. Any ways seriously I'm wondering if the little GPS's we all have in our copters suffer a similar thing ?.
Now I'm going to cut and paste something which if anyone can be bothered finding out, it may solve/aid in the mystery...
"RAIM detects faults with redundant GPS pseudorange measurements. That is, when more satellites are available than needed to produce a position fix, the extra pseudoranges should all be consistent with the computed position. A pseudorange that differs significantly from the expected value (i.e., an outlier) may indicate a fault of the associated satellite or another signal integrity problem (e.g., ionospheric dispersion). Traditional RAIM uses fault detection (FD) only, however newer GPS receivers incorporate fault detection and exclusion (FDE) which enables them to continue to operate in the presence of a GPS failure.
The test statistic used is a function of the pseudorange measurement residual (the difference between the expected measurement and the observed measurement) and the amount of redundancy. The test statistic is compared with a threshold value, which is determined based on the requirement probability of false alarm (Pfa).
RAIM
Receiver autonomous integrity monitoring (RAIM) provides integrity monitoring of GPS for aviation applications. In order for a GPS receiver to perform RAIM or fault detection (FD) function, a minimum of five visible satellites with satisfactory geometry must be visible to it. RAIM has various kind of implementations; one of them performs consistency checks between all position solutions obtained with various subsets of the visible satellites. The receiver provides an alert to the pilot if the consistency checks fail.
RAIM availability is an important issue when using such kind of algorithm in safety-critical applications (as the aeronautical ones); in fact, because of geometry and satellite service maintenance, RAIM is not always available at all, meaning that the receiver's antenna could have sometimes fewer than five satellites in view.
Availability is also a performance indicator of the RAIM algorithm. Availability is a function of the geometry of the constellation which is in view and of other environmental conditions. If availability is seen in this way it is clear that it is not an on–off feature meaning that the algorithm could be available but not with the required performance of detecting a failure when it happens. So availability is a performance factor of the algorithm and characterizes each one of the different kinds of RAIM algorithms and methodologies.
Fault detection and exclusion
An enhanced version of RAIM employed in some receivers is known as fault detection and exclusion (FDE). It uses a minimum of six satellites to not only detect a possible faulty satellite, but to exclude it from the navigation solution so the navigation function can continue without interruption. The goal of fault detection is to detect the presence of a positioning failure. Upon detection, proper fault exclusion determines and excludes the source of the failure (without necessarily identifying the individual source causing the problem), thereby allowing GNSS navigation to continue without interruption. The availability of RAIM and FDE will be slightly lower for mid-latitude operations and slightly higher for equatorial and high-latitude regions due to the nature of the orbits. The use of satellites from multiple GNSS constellations or the use of SBAS satellites as additional ranging sources can improve the availability of RAIM and FDE.
RAIM prediction
GNSS differs from traditional navigation systems because the satellites and areas of degraded coverage are in constant motion. Therefore, if a satellite fails or is taken out of service for maintenance, it is not immediately clear which areas of the airspace will be affected, if any. The location and duration of these outages can be predicted with the aid of computer analysis and reported to pilots during the pre-flight planning process. This prediction process is, however, not fully representative of all RAIM implementations in the different models of receivers. Prediction tools are usually conservative and thus predict lower availability than that actually encountered in flight to provide protection for the lowest end receiver models.
Because RAIM operates autonomously, that is without the assistance of external signals, it requires redundant pseudorange measurements. To obtain a 3D position solution, at least four measurements are required. To detect a fault, at least 5 measurements are required, and to isolate and exclude a fault, at least six measurements are required, however often more measurements are needed depending on the satellite geometry. Typically there are seven to 12 satellites in view.
The test statistic used is a function of the pseudorange measurement residual (the difference between the expected measurement and the observed measurement) and the amount of redundancy. The test statistic is compared with a threshold value, which is determined based on the requirements for the probability of false alarm (Pfa) and the expected measurement noise. In aviation systems, the Pfa is fixed at 1/15000.
The horizontal integrity limit (HIL) or horizontal protection limit (HPL) is a figure which represents the radius of a circle which is centered on the GPS position solution and is guaranteed to contain the true position of the receiver to within the specifications of the RAIM scheme (i.e. which meets the Pfa and Pmd). The HPL is calculated as a function of the RAIM threshold and the satellite geometry at the time of the measurements. The HPL is compared with the horizontal alarm limit (HAL) to determine if RAIM is available."
