Fisheye effect during tilt - can it be reduced?
Hi guys
I´ve just bought a second hand P2V+ and this is my first DJI drone. Took it out for a spin for the first time today and so far I really feel it was a real upgrade from my Bebop and other drones :)
Just have one question: When flying on a straight path I had the gimbal tilted all the way down and wanted to make a reveal shot tilting the camera slowly up and towards the front/horizon. This shot became useless because the fisheye effect was reaaaaally bad on the way up.
Is it really that bad? For me that means that you can´t use it for anything else than adjusting the angle BETWEEN shots, not able to use it for effects WHILE recording if you know what I mean.
Also, whats the best settings to reduce rolling shutter?
Edit: uploaded the clip:
The wide FOV is the culprit, unfortunately there's nothing you can do but try to correct it in post.
Any tips for automated software that would fix this for me? I tried Prodreanlin but the emulated Mac version kind of sucks.
I don't think you need to adjust your rolling shutter. But if you need to, then you may need to invest in Neutral Density filters.
But I think the issue you have is your ISO is on auto. Lock your ISO to 100 and try again.
Would setting video to narrow fov not alleviate the fisheye problem?
I use prodrenaline on an i5 pc & find the preset for gopro 3 (narrow) does a good job of stretching out the odd clip that needs attention: Most are fine as is.
