Fisheye effect during tilt - can it be reduced?
Discussion in 'Phantom 2 Vision + Help' started by skiftun, Dec 11, 2015.
  1. skiftun
    Hi guys
    I´ve just bought a second hand P2V+ and this is my first DJI drone. Took it out for a spin for the first time today and so far I really feel it was a real upgrade from my Bebop and other drones :)
    Just have one question: When flying on a straight path I had the gimbal tilted all the way down and wanted to make a reveal shot tilting the camera slowly up and towards the front/horizon. This shot became useless because the fisheye effect was reaaaaally bad on the way up.
    Is it really that bad? For me that means that you can´t use it for anything else than adjusting the angle BETWEEN shots, not able to use it for effects WHILE recording if you know what I mean.
    Also, whats the best settings to reduce rolling shutter?
    Edit: uploaded the clip:
    #1 skiftun, Dec 11, 2015
  2. bbfpv
    Long Island, NY
    The wide FOV is the culprit, unfortunately there's nothing you can do but try to correct it in post.
  3. skiftun
    Well that sucks..!
  4. skiftun
    Any tips for automated software that would fix this for me? I tried Prodreanlin but the emulated Mac version kind of sucks.
  5. sdtag
  6. Mako79
    Sydney Australia
    I don't think you need to adjust your rolling shutter. But if you need to, then you may need to invest in Neutral Density filters.
    But I think the issue you have is your ISO is on auto. Lock your ISO to 100 and try again.
  7. jackhandy
    Would setting video to narrow fov not alleviate the fisheye problem?
    I use prodrenaline on an i5 pc & find the preset for gopro 3 (narrow) does a good job of stretching out the odd clip that needs attention: Most are fine as is.
Similar Threads - Fisheye effect during Forum Date
How do you get rid of that fisheye effect on videos on a non- gopro camera? Editing (Photo and Video) Nov 30, 2015
still photos fisheye effect removal Phantom 2 Vision + Discussion Feb 19, 2015
Final Cut Pro X used for removing the "FishEye" effect. DJI Ground Station Apr 13, 2014
Camera tilt increases the fisheye effect why? Phantom 2 Vision Discussion Feb 12, 2014
FS: GoPro Hero 3+ Black - Modified with 5.4mm Lens! No Fisheye! Classifieds Feb 19, 2016
