First crash, what to check?
South Yorkshire, UK
Had my P3A for a little while now and love it, no issues and a joy to fly.
Had a small meeting with a tree a couple of days ago, about 30ft up and dropped to the ground. No visible damage, just a muddy arm and props. I tried a test flight and all was fine. I noticed the top part of the shell was very slightly dislodged but this clicked back over the bottom part with a thin piece of plastic used to repair an iPhone screen.
I've calibrated gimball and IMU - no issues there. Further test flights for over an hour and all OK so far.
Is there anything else worth checking either as precaution or good maintenance?
I would replace the props for sure.
If it hovers in place and reacts correctly to stick controls I think you got lucky.
The camera is the only other thing that might be out of wack.
I agree, worth swapping props. Camera looks and controls fine so this was a lucky one. Thanks for your quick response :)
I would take the top off and check all the connections and also look at the GPS antenna to be sure it still is a solid connection and the delicate porceline of the antenna is not cracked
brianklenhart
