First crash - a major one and camera not working?
Hi,
I'm a complete novice and on my 3rd outing earlier today I have managed to collide with a tree branch approx. 40ft up resulting in the P2 falling rather ungracefully to the ground below.
The outcome was that whilst all the motors fire up and props are OK, there is no live feed to the screen on the mobile, just a blank black one.
I'm not sure what 'next steps' I need to take or run through to see what needs to be done.
Is there a kind of check list to follow and a correction for the issue with screen.
The camera also appears to be in a 'hanging state' - again can you calibrate the camera as it's probably this which is the issue with the blank screen.
Thanks.
Sounds like a damaged ribbon cable!
Does the camera move at all? Or just hang limp?
But most likely a ribbon cable issue, they are easy!
HINT: START at camera, then work the ribbon twords THE PITCH board, then to ROLL board, and End at gimbal base, ( Yaw ) where large motherboard is!.
Take pics or video of you removing the old one as reference to installing new one!
Hope this helps
J Dot
:cool:
Reactions: Mark The Droner
Usachman
