Hi All,
Just wondering if anyone can help me.
I've not flown my Phantom 3 Pro for about 4 months, so I figured that I should check for updates.
The last update I did was to bring the controller firmware up to v1.3.20 in order to enable updates from the DJI Go app.
Given the issues with batteries that I've been reading about, I thought it wise to go with the 1.6.0040 update.
My first step was to copy the file to the micro SD card, insert it, and then power on the Phantom.
The upgrade process took about 25 minutes, and I got a 'good' status at the end of it.
I then went into the DJI Go app, and it reports App v2.6.0, Aircraft 1.3.20+ and RC v1.3.20.
This doesn't seem correct to me. If I check the firmware log, then I see the following:
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.06.0040.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
My assumption is that the 2nd and 3rd sucess entries refer to the battery updates, as I've got 3 batteries in total.
If we look at the more advanced log from MISC/LOG on the SD card, then I see the following:
[00013905]========== remo-con disconnect. boot(15) ============
[00013963]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x70dee2b9].
[00014013]Packet upgrade start...
[00014066]Packet checking...
[00014123]Packet vlink 01.06.0040 <-> 01.05.0030.
[00014178]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00014229]Done.
[00014282]Version checking[1]...
[00014365][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014446][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00014499][04 00][00] v1.41.0.0 -> v1.41.0.0
[00014646][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00014744][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014865][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014979][12 02][00] v1.10.0.0 -> v1.10.0.0
[00015079][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015307][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015414][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015557][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015630][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015683][01 00][00] v1.23.3419 -> v1.26.4315 need upgrade
[00015739][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00015801][08 00][00] v0.12.0.4 -> v0.13.0.7 need upgrade.
[00015870][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00015928]Done.
[00017978]Waiting for user confirm...
[00028037]Timeout, start upgrade automatically.
[00028140]Firmware upgrading[1]...
[00040267][01 00] Firmware upgrade start...
[00012229][01 00] Firmware upgrade finished successfully.
[00012377]Done.
[00012433]Packet [C:\P3X_FW_V01.06.0040.bin] resumed, card sn [0x70dee2b9].
[00012485]Packet vlink 01.06.0040 <-> 01.05.0030.
[00012554]Record vlink 01.04.0010 <-> 01.03.0020 (flow = 0).
[00012603]Version checking[2]...
[00012716][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012810][03 06][00] v2.3.0.13 -> v2.4.10.7 need upgrade.
[00012956][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013177][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00013305][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013415][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013523][12 02][00] v1.10.0.0 -> v1.10.0.0
[00013627][12 03][00] v1.10.0.0 -> v1.10.0.0
[00013785][15 00][00] v1.1.2.0 -> v1.1.2.0
[00013883][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014022][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014093][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014231][01 00][05] v1.26.4315 -> v1.26.4315
[00014366][01 01][00] v1.23.3419 -> v1.26.4315 need upgrade
[00014427][08 00][00] v0.12.0.4 -> v0.13.0.7 need upgrade.
[00014493][09 00][00] v1.7.0.3 -> v2.13.0.0 need upgrade.
[00014546]Done.
[00014601]Firmware upgrading[2]...
[00014769][01 01] Firmware upgrade start...
[00045050][01 01] Firmware upgrade finished successfully.
[00045953][08 00] Firmware upgrade start...
[00562509][08 00] Firmware upgrade finished successfully.
[00562660][11 00] Firmware upgrade start...
[00610359][11 00] Firmware upgrade finished successfully.
[00610616][03 06] Firmware upgrade start...
[00959760][03 06] Firmware upgrade finished successfully.
[00959841][09 00] Firmware upgrade start...
[01013305][09 00] Firmware upgrade finished successfully.
[01013359]Done.
[01013412]Version checking[3]...
[01013509][03 05][00] v34.2.0.9 -> v34.2.0.9
[01013583][03 06][05] v2.4.10.7 -> v2.4.10.7
[01013653][04 00][00] v1.41.0.0 -> v1.41.0.0
[01013785][11 00][05] v1.7.15.1 -> v1.7.15.1
[01013883][12 00][00] v1.10.0.0 -> v1.10.0.0
[01013983][12 01][00] v1.10.0.0 -> v1.10.0.0
[01014083][12 02][00] v1.10.0.0 -> v1.10.0.0
[01014192][12 03][00] v1.10.0.0 -> v1.10.0.0
[01014380][15 00][00] v1.1.2.0 -> v1.1.2.0
[01014493][17 00][00] v1.1.1.7 -> v1.1.1.7
[01014633][17 01][00] v1.0.2.7 -> v1.0.2.7
[01014698][19 00][00] v1.0.8.96 -> v1.0.8.96
[01014757][01 00][05] v1.26.4315 -> v1.26.4315
[01014809][01 01][05] v1.26.4315 -> v1.26.4315
[01014884][08 00][05] v0.13.0.7 -> v0.13.0.7
[01014958][09 00][05] v2.13.0.0 -> v2.13.0.0
[01015010]Packet upgrade finish successfully.
[00013111]========== remo-con disconnect. boot(15) ============
[00013171]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x70dee2b9].
[00013224]Packet upgrade start...
[00013280]Packet checking...
[00013339]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013394]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013447]Done.
[00013500]Version checking[1]...
[00013597][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013698][03 06][00] v2.4.10.7 -> v2.4.10.7
[00013756][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013898][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00014012][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014138][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014247][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014342][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014506][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014602][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014842][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014918][19 00][00] v1.0.8.96 -> v1.0.8.96
[00014972][01 00][00] v1.26.4315 -> v1.26.4315
[00015027][01 01][00] v1.26.4315 -> v1.26.4315
[00015098][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015172][09 00][00] v2.13.0.0 -> v2.13.0.0
[00015227]Done.
[00017286]Waiting for user confirm...
[00027342]Timeout, start upgrade automatically.
[00027456]Firmware upgrading[1]...
[00027521][11 00] Firmware upgrade start...
[00076711][11 00] Firmware upgrade finished successfully.
[00076772]Done.
[00076827]Version checking[2]...
[00076922][03 05][00] v34.2.0.9 -> v34.2.0.9
[00077023][03 06][00] v2.4.10.7 -> v2.4.10.7
[00077083][04 00][00] v1.41.0.0 -> v1.41.0.0
[00077241][11 00][05] v1.7.15.1 -> v1.7.15.1
[00077344][12 00][00] v1.10.0.0 -> v1.10.0.0
[00077444][12 01][00] v1.10.0.0 -> v1.10.0.0
[00077569][12 02][00] v1.10.0.0 -> v1.10.0.0
[00077694][12 03][00] v1.10.0.0 -> v1.10.0.0
[00077838][15 00][00] v1.1.2.0 -> v1.1.2.0
[00077944][17 00][00] v1.1.1.7 -> v1.1.1.7
[00078119][17 01][00] v1.0.2.7 -> v1.0.2.7
[00078196][19 00][00] v1.0.8.96 -> v1.0.8.96
[00078252][01 00][00] v1.26.4315 -> v1.26.4315
[00078310][01 01][00] v1.26.4315 -> v1.26.4315
[00078373][08 00][00] v0.13.0.7 -> v0.13.0.7
[00078456][09 00][00] v2.13.0.0 -> v2.13.0.0
[00078508]Packet upgrade finish successfully.
[00013223]========== remo-con disconnect. boot(15) ============
[00013281]Packet [C:\P3X_FW_V01.06.0040.bin] detected, card sn [0x70dee2b9].
[00013339]Packet upgrade start...
[00013399]Packet checking...
[00013460]Packet vlink 01.06.0040 <-> 01.05.0030.
[00013513]Record vlink 01.06.0040 <-> 01.05.0030 (flow = 0).
[00013566]Done.
[00013625]Version checking[1]...
[00013717][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013798][03 06][00] v2.4.10.7 -> v2.4.10.7
[00013863][04 00][00] v1.41.0.0 -> v1.41.0.0
[00013998][11 00][00] v1.7.0.0 -> v1.7.15.1 need upgrade.
[00014091][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014191][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014402][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014501][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014648][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014741][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014882][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014947][19 00][00] v1.0.8.96 -> v1.0.8.96
[00015003][01 00][00] v1.26.4315 -> v1.26.4315
[00015064][01 01][00] v1.26.4315 -> v1.26.4315
[00015135][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015206][09 00][00] v2.13.0.0 -> v2.13.0.0
[00015261]Done.
[00017320]Waiting for user confirm...
[00027374]Timeout, start upgrade automatically.
[00027485]Firmware upgrading[1]...
[00027553][11 00] Firmware upgrade start...
[00077134][11 00] Firmware upgrade finished successfully.
[00077189]Done.
[00077246]Version checking[2]...
[00077341][03 05][00] v34.2.0.9 -> v34.2.0.9
[00077421][03 06][00] v2.4.10.7 -> v2.4.10.7
[00077486][04 00][00] v1.41.0.0 -> v1.41.0.0
[00077602][11 00][05] v1.7.15.1 -> v1.7.15.1
[00077705][12 00][00] v1.10.0.0 -> v1.10.0.0
[00077804][12 01][00] v1.10.0.0 -> v1.10.0.0
[00077904][12 02][00] v1.10.0.0 -> v1.10.0.0
[00078004][12 03][00] v1.10.0.0 -> v1.10.0.0
[00078168][15 00][00] v1.1.2.0 -> v1.1.2.0
[00078290][17 00][00] v1.1.1.7 -> v1.1.1.7
[00078430][17 01][00] v1.0.2.7 -> v1.0.2.7
[00078509][19 00][00] v1.0.8.96 -> v1.0.8.96
[00078570][01 00][00] v1.26.4315 -> v1.26.4315
[00078623][01 01][00] v1.26.4315 -> v1.26.4315
[00078690][08 00][00] v0.13.0.7 -> v0.13.0.7
[00078770][09 00][00] v2.13.0.0 -> v2.13.0.0
[00078826]Packet upgrade finish successfully.
From what I can see, this indicates that all of the firmware on the aircraft and batteries is up to date.
However, this isn't reflected in the firmware version shown in the DJI Go app.
I did find another thread on here which talks about this mismatch (http://www.phantompilots.com/threads/1-3-20-what-does-this-mean.53835/).
The suggestion in this thread is that dragging and dropping the firmware file to the SD card was the cause, and that copying and pasting fixes the issue. I'm at a loss to explain why, and certainly this fix does not address the issue for me.
Can anyone suggest why my firmware version is not displaying correctly?
What should the app being showing?
I've also not got any notifications of firmware updates for the controller. Is 1.3.20 the latest version for the RC?
Any help would be much appreciated.
Regards,
Andy.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
[00014229]Done.
[00015928]Done.
[00012377]Done.
[00014546]Done.
[01013359]Done.
[00013447]Done.
[00015227]Done.
[00076772]Done.
[00013566]Done.
[00015261]Done.
[00077189]Done.
Regards,
Andy.
