Hello there I am trying to upgarde to latest firmware but only get failed messages eeven after ensuring I hace connected to internet before uploadingYou can update the firmware from DJI GO like this:
Hello "failed to download upgrade" or No internet connection when connected to the RC and aircraft " so totally stuck as far as progressingWhat kind of failed messages are you seeing?
Yes definately right next to modem so at full strength wi-fi trying to do exactly as p3 standard steps in tutorialAre you sure your mobile device is connected to the Internet?
Yes fully able to switch between home wi fi and phantom wi fiDoes your mobile device show it's connected to the Internet before you try to download the update in DJI GO?
what problems did it give you that you had to get rid of it?Don't upgrade P3 SE firmware, I did, and I had to get rid of it...
If you update your firmware on your drone do you have to update your rc also if yes how do you do that.
Thanks for your information
I’ve had no issues with the latest firm ware for my Se (Australia)
1 ,make sure you are connected to your home wifi or you mobile data is ON
Open Go app and click on upgrade This should down load to your phone [emoji336] or whatever device the Go app is installed on
Once downloaded you’ll need to turn on the drone and maybe the rc as well
2 connect to the drone wifi as per instruction manual
3 open go app click on upgrade follow prompts
Do you have to update firmware on RC or does this process do bothYou can update the firmware from DJI GO like this:
