FCC CE
So i know how this works, but i can't believe the is no way to override this. Can someone explain it? I am CE and the distance is so low.
Your Phantom will auto set that setting based on its GPS location.
I Know That. How can i override this? And come on, someone had found a way. It's not NSA, it's DJI
You cannot override the Phantom's GPS location. Nor can you manually toggle that setting elsewhere.
Well, if you figure it out, let us know :)
No i can't believe that..
I know i sound crazy, but seriously guys? All this community and no one managed to break the code? That's why i'm insisting
Reactions: curiosity
Never tried it but believe there should be an indoor startup method that bypasses GPS
Have heard that enclosing GPS antenna with aluminium/copper is enough to disable it.
On the other hand, what happens when there is GPS signal loss in flight?
You join Sunday and come in here and insist .Just want to be spoon-fed .You be serious .
Reactions: N017RW
robvalduga
