I was flying a mapping mission at a rock quarry using Map Pilot with the terrain awareness feature. I have used the same software with two different P4P aircraft on this site three times previously without any problems.
The first three batteries went fine, but after taking off on the fourth battery something went wrong. Although the aircraft was following the terrain, as it approached a steep slope it didn't gain enough altitude and hit a bush on the top. After an hour climb up along the Bighorn Sheep trails, I recovered the aircraft. (Came back down the blasting road I found at the top...)
Here is the odd part, the KML exported from Airdata in Google Earth shows the aircraft climbing as expected, and it is also shown above the top of the hill, where it was supposed to be, but obviously, it was not.
The DAT files also show something odd, there are multiple files with timestamps going forward and back in time.
01/31/2018 11:16 AM 165,138,432 FLY102.DAT
01/31/2018 11:41 AM 171,307,008 FLY103.DAT
01/31/2018 12:03 PM 156,315,648 FLY104.DAT
01/31/2018 12:27 PM 173,850,624 FLY105.DAT
01/31/2018 12:28 PM 61,276,160 FLY106.DAT
01/31/2018 12:33 PM 33,554,432 FLY107.DAT
01/31/2018 12:35 PM 45,109,248 FLY108.DAT
01/31/2018 12:28 PM 225,280 FLY109.DAT
01/31/2018 12:32 PM 25,780,224 FLY110.DAT
01/31/2018 12:28 PM 12,288 FLY111.DAT
01/31/2018 12:28 PM 118,784 FLY112.DAT
The battery was laying next to the aircraft, so it would appear to have popped out when it hit the ground.
The aircraft is operating fine on the workbench, the IMU was showing good but I recalibrated anyway. Will take it out this weekend for a cautious test flight, but not sure how to accurately test the altitude reading. Maybe fly both p4P's next to each other and compare readings? This was not a case of it being a few feet off as might be expected, it should have been 220 feet higher than the top of the hill.
