The beeping is often due to a firmware update attempt that failed. Is it possible that you ended the procedure prematurely?
If this sounds like your issue, start over from scratch and follow all of the steps, and then let it update the firmware for at least 30 minutes. It will continue to beep for all of that time, I'm afraid, so you might want to place it in a place where the beeping doesn't bother you.
Chris
