Errore
hello my phantom 3 advanced so is with endless high beeps, the LED does not light up and can not update the firmware, the drone never suffered falls! Can someone help me please!
The beeping is often due to a firmware update attempt that failed. Is it possible that you ended the procedure prematurely?
If this sounds like your issue, start over from scratch and follow all of the steps, and then let it update the firmware for at least 30 minutes. It will continue to beep for all of that time, I'm afraid, so you might want to place it in a place where the beeping doesn't bother you.
Chris
Pauos31
