Error message
Ultrasonic system error ..please explain....
Sure, but a bit more information would certainly help. In base terms, the Ultrasonic systems are the OAV sensors........
Thanks was flying drone got message "ultrasonic system error land immediately ". Didn't see message until reviewing flight log ... two days later next flight 5min into flight 100% battery . Got "Aircraft disconnected" . Reviewed flight log .. found drone totaled fell thru trees ....now what are OAV 'S. .. Is disconnect related to OAV or ULTRASONIC SYSTEM??? Thanks Viper35
Most likely unrelated. "Obstacle Avoidance Sensors" are what the message refers to. If you would like additional information on the flight from others, you will need to share that log here. If you have not done so already, follow the link below and upload your flight log and share the link back here. ( Note: If you are using Airdata, you can share that link, but you will need to make it fully sharable such that we can retrieve the .csv file ).
DJI Flight Log Viewer
tpren3
