WHY DO THE EXTERNALS NOT EXPLODE AFTER SOME CHARGING TIME?
(next problem: if you connect the balance leads from the dji batt to the externals balance connector
while the externals are empty and the dji bat is full or the other way around,
the cells of the fuller bat will immediately start "charging" the cells ot the emptier one
through the balance leads without any electronics with an extreme current, only limited by the wire resistance, so you are not supposed to do that, or what?)
do i missunderstand any terminology, isnt it true that the SWITCHED SIDE of the smartboard solder joints is directly connected, without any electronics in between, to the dji bat plug ? is there a tiny diode somewhere?
i had to get some more coffee and re-read that, honestly i dont know why the power doesnt go back to the externals, or why it doesnt overload. That part of electrical engineering is past me man! I just know it works, maybe someone more technical can help answer that question
