Dual Battery Mod
I bought 2x Haiyin 2s 2400 lihv 's weighing 134 gr , one on each side similar to a 4s 2400 268gr . Took a test flight today at 0°c and got 26min flight time with 15% left.
How do you connect 2S batteries?
If you connect your two 2S packs in series, you'll get a single 4S pack.
And two 2s 2400mah packs are almost always lighter than two 4s 1200mah packs
Can you share a picture of your serial connection?
And why again would 2 2s be better than 2 4s? I usually use 2 4s 2400 each parallel...
it is not necessary better but it was the best choice my local hobby shop had to weight ratio.
If I get hold of two hyperion 2s 2400 hv batteries that weigh just over 100gr each then I certainly get 1min more flying time ie 27 min in only 200gr payload.
That's quite amazing. Odd that no one thought about doing it this way!
2x 2s 2400 = 1x 4s 2400. Right?
2x2s/2400 hyperion=216gr. Flight time 26-28 min. Not world record but cheaper, less stress for the motors/props/esc.
Did you find a good retailer to buy the 2s Hyperion and the carbon fiber battery platforms?
I do not know of anyone who has both but I have not looked for it either.
I use fpvlr mounts since they came with the air side booster kit i use.
I have just dismantled a phantom 3 battery to split the package in 2 x 2s / 4480mah lihv 's. They weigh 161gr each with cable and xt 60. 322gr total .
muskansahu
