Drone fishing/drop rig setup
Discussion in 'Pro/Adv Discussion' started by Scotty88, Jul 28, 2016.
  1. Scotty88
    Hey all,
    Getting comfortable enough with my p3 and now ready to drop baits out to sea. I have tried a setup with elastics but failed as was too unreliable. Hoping someone out there could share some knowledge on a fishing setup?
    I have seen a maze design dropper which was pretty cool but can't find a supplier. I saw a guy down in Cape Town who had a dedicated bait dropper, was a bright orange drone but heck it was pricy!
  2. Imabiggles
    light rubber band. Buy the skinniest you can find. If they break too soon, use two.
  3. fastfed
    There was a few I saw using a metal hanger and rigging it up on the legs, the hanger would act simply as a holder a drop weight, teardrop shape.
    Then after you get out to your spot, do a full backward run on the drone while kinda pullin the rod (Scary) and it comes off.
    I'd be scared shitless to be honest, I plan on doing this, but what if I'm spooling out my line and it gets caught, either a bad spool job or a knot.
    John searle likes this.
  4. John searle
    Mandurah. West aust
    Try useing a clothes peg tied to one leg of drone. Then wrap a rubber band around the bottom part of the peg to allow for adjustment of preasure to the opening part of peg. Then you pass the fishing line though the part below the rubber band . This should run frealy .place a lead weight on the line along with your bait. After testing it on an open area up to say 200 mtrs. Then flick the fishing rod sharply down and this should then release the line.
    Trial and error with the rubber band around the peg will be required until you are happy with the release.
    Very cheap and your wife/mum want even mis the clothes peg.
  5. Scotty88
    Thanks for the tip John! Just one question when I flick the rod do I have to have tension on the line with the drag set right or just slack line?
  6. John searle
    Mandurah. West aust
    Keep line taut just enough so it does not affect the drone at hover. It works well and cost. Zero
  7. dirkclod
    dirkclod Moderator
    Staff Member
    Amory Mississippi
    Here is a 11 page thread on some ways members came up with things to do this .Might look through them
    and see what they learned Drone Fishing .
    Good luck .
  8. Scotty88
    Thanks man appreciated let the fishing begin
    dirkclod likes this.
  9. fastfed
    I like the one where the guy uses the pin and antenna tube
    the only thing I fear is the line hitting the props, if it even hits it once, its gone, iguess the trick is altitude, make sure you go high
  10. voi9viper
    This one should be even easier. Glue a hook to the camera gimbal, then tip the camera down to release. Only worry here is burning out the gimbal motor. I'd add a simple 900 mghz telemetry module and an extra toggle to my remote to trigger a servo. I'll give this a thought and see what I come up with. I'm looking to use my drone to spot feeding fish away from the boat, but I really need longer flight time.
  11. kingfisher555
    Capac Mi USA
    use a line clip the you use to clip your line on from a down rigger.
  12. M1shootr
    Howard, Ohio
    My thoughts too. +1
  13. Corey Tucker
    I bought a drop kit - not to go fishing with but should work. I wouldn't ever put anything on the camera - that seems like a bad idea. If you ever take it fishing make sure to post video. i saw the one video that everyone talks about but would like to know if that is as easy as they make it seem.
    anyway - here's what i got. only tried it twice, the first time it worked but at 1000 ft it didn't so not sure if i recommend it.
    Gimbal-Guard
  14. thunderbird
    Montreal, Quebec
    If it runs on 3.7V then you have a problem where it might not work after few release/lock as servo operates on 4.8V, That's the reason I made mine 5V Operated
  15. RottweilerluvNZ
    Aotearoa
    Drop kit works well, I decided to just get one rather than risking some pull to drop rig or something like that. You just swipe the control on the app and - ater bait and sinker!. Just finished off 4 successful wet drops into the mighty Atlantic!!! will post vid shortly, pretty happy about it so far.
    Learned a great deal from the experience, will be keen to share some of it might come of use to other's thinking about going out bait dropping over surf.
    Going to head to a non surf beach next to see the difference.
  16. bszaronos
    *** Watch the line on the fishing pole ****
    My daughters boyfriend and I made a drop line for my drone. I tested it out before hand to make sure it would work.
    We took it out to the ocean and everything was going great. The drone had the line and was cruising out over the water. Then I heard those last words "My line !!"
    Turns out that I did not take into account that the fishing pole has a limited amount of fishing line. We were both watching the drone and when we reached the end of the fishing line, he held onto the fishing pole
    and the drone went straight into the water. Never to be seen again.
  17. Vaneik
    santander
    And Nice house.
  18. rstekeur
    Ft Myers, Florida
    I'd probably use a DJI 450 or something similar and a Taranis radio and set up a spare channel with a servo to release the weight
  19. thunderbird
    Montreal, Quebec
  20. AllDubyas
    Ok that looks great! How'd you make your drop kit?
Similar Threads - Drone fishing drop Forum Date
Drone Fishing for the First Time Tomorrow... General Discussion Nov 21, 2017
Fishing ship in Iceland.Drone Flight From Iceland.(DJI PHANTOM 3 4K ) FPV (First Person View) Nov 5, 2017
rigging a fishing line for drone fishing- need guidance General Discussion Mar 21, 2017
Fishing with the Drone - Was Funny! Photos and Video Oct 22, 2016
Drone fishing with live bait. Fraser Island Australia Photos and Video Oct 8, 2016
