Downgrading firmware on P3P from 1.10.9 to 1.7.6
Just checked everything again.
Camera works as it should, recorded a short video, it's good.
I have GO 2.4.2, RC is 1.6, and the AC is 1.8.80+! So I was successful in downgrading, but went a little further than expected. I had 1.9.6 on the sd card with the debug. I want 1.9.6 so that is a straight upgrade I believe?
1.8.80+ could also be 1.9.60 and you couldn't go to 1.8.80 unless you had it on the SD card.
I don't know what happened. Last night it looked like I still had AC 1.10.
FW 1.9.6 was on the sd card. Don't know how it went to 1.8.80+.
i am almost tempted to say downgrade to 1.7.6 normally, then re-flash 1.7.6 with the debug file. you should then be on 1.7.6 and you can go where ever you want from there
do not use the debug file at this point. untill you have downagrade to 1.7.6 the normal way if it lets you. then your also going to need to downgrade your remote controller. to 1.5.8
if you still end up on 1,8+ after that then try to install 1.9 the normal way. if that dont work then your going to need to follow my above instructions
I already started redoing 1.9.6 before I got your reply. Should I let it run or stop. I'm leaning towards letting it run.
OK, will let it run.
your installing 1.9 with debug right now? thats okay. what version are you trying to get to?
Yes.
Want to drop to 1.9.6.
GO 2.9.1, RC 1.8, and AC 1.9.6 seemed to work good for me.
At least I know how to go back further if I want to.
Had trouble with GO 1.10 and GO 3.1.2.
I got a notice earlier to upgrade to GO 3.1.3.
Has anyone else got a notice?
AlienzEyes
