Does Anyone Have Wide Legs - Compass Problem ?
I'm planning on buying some wide legs for my P2 but am concerened that any small difference in orientation will throw off directional control. Has anyone fitted wide legs successfully and if so what type please ?
derrickduff said:
There shouldn't be a problem as long as you recalibrate the compass after you've replaced the legs.
And you place compass in same vicinity and facing same direction.
Only issue is the wire harness for the iOSD mini plug does not fit properly, you have to tape it on there or lengthen the harness.
The compass harness bolts on with no issues...
I have a set of those legs on order but have read reports that they are flimsy compared to the originals. What is the orange coil you have zip tied to yours? does it help with the strength?
