dji warranty repair
had a battery shut off in mid flight 20 feet above the ground and the phantom took a digger about a month ago. so I sent it in to DJI and they replaced the battery all 4 engines the naza and basically everything minus the camera... ill fly it sometime tomorrow maybe but im a little hesitant to say the least.
anyways i have heard talk of new battery pins but not sure what to look for to see if those got addressed as well. does anyone know about this?
I just plugged in everything to the assistants and verified its all up to date and im charging the bats now.
Hmm not sure...
Pull_Up said:
Yep, those are mk2 pins. My original-style ones just have a smooth single point at the end, not crowned like those.
Anybody know if this part is soldered or plugged in?
Thanks...
-slinger
The former needles have been replaced with pins sporting 4-points each. The Red & Black leads from the old connector need to be unsoldered from the Central Board, then resoldered with the leads from the new connector. The smaller battery data cable has a plug on the end that disconnects easily.
iDrone
iDrone
Sounds like you may have replaced yours already?
iDrone
Thank you, sir... :D
-slinger
Johnboy94
