DJI Phantom 2 with H4-3D purchase?
Hey guys, kinda a newbie.
I currently have a P2V+ with broken camera and about 30 hours flight time.
I have a chance to get a used DJI Phantom 2 with H4-3D. I already have a GoPro.
Any thoughts or advice?
Any suggestions on what program I need to use with flight data(with camera view)? What FPV, transmitter and receiver? Medium to long range, looking for easy install, :)
Mike
Sent from my iPod touch using PhantomPilots mobile app
Mike
How much is the P2 with H4-3D?
How much is the H4-3D by itself?
If you know how to pull apart the P2V+ then have a read of the link below.
DJI Phantom 2 Vision+ Plus 2.4ghz Wifi Module - wiring diagram / camera connection - Page 17 - RC Groups
You basically use the existing system but change the eyes.
You can still control tilt but you can no control the camera (eg stop/start, settings)
An Android phone works best. IOS will require third party apps.
Its cheaper as it will not require you to buy analogue transmitter/receiver/display/mini IOSD etc.
There is no soldering required - you just need to purchase a $10 longer zenmuse cable, and redirect 1 plug back into the cam port to power up the wifi module.
You will still get the same FPV range as you always have.
You will however lose flight time as the P2V+ is a little heavier.
You should also look into a P3 standard or advanced.
The h4-3D is already installed, was that DJI package deal, $350 with case, looks like mint, thoughts?
