DJI Lens Correction for Videos
Help. I opened the video clip with Photoshop and applied the DJI lens correction to straighten out the fisheye effect. However, now when I play it back it plays in slow motion. Question: How do you get Photoshop to play the clip at regular speed? Thanks.
You need to render it back into a regular video file. File->Export->Render Video.
Once you've applied the lens correction, Photoshop has to re-build every frame of this modified video in real-time - and your computer is NOWHERE NEAR FAST ENOUGH to do that.
I've got a better solution for you. Shoot your videos in 90 degree angle like I do so you get virtually no lens distortion or fisheye that way.
rmklaw said:
Thanks. I am doing it now. Slow process.
Yep, Photoshop renders video very slowly, and has limited rendering choices. Dedicated video apps like Adobe Premiere, Adobe After Effects, Sony Vegas or others will render video much faster and make better use of your CPUs and GPUs processing power. Photoshop's automatic correction based on lens profiles is nice - but for video it may not be worth putting up with Photoshop's slow rendering.
It may be better to use the built-in lens-distortion correction filters found in dedicated video apps - like the one in After Effects. Not automatic based on a lens profile, but it's easy to manually move a slider until it looks good. And they render a lot faster than Photoshop.
A question for those more versed in the ins and outs of lenses than I...
When DJI release the 46mm lens filter adapter kit, is there anything available that could be fitted to that to do a correction? Or is putting it in front of the lens just not going to work? As you can tell, I have no idea about any of this!
Also, does anyone have any video they can share which they took with the 90 degree FOV, just to compare? Thanks...
quote]
I would think it would have to have multiple elements and thus more weight. I have a very old telephoto converter for my camcorder that is like this one except mine is 1.5x instead of 2x:
http://www.amazon.com/Digital-Optics-Pr ... +lens+46mm
I hand-held it in front of the Vision camera and it did reduce the distortion as well as making things look closer. Like the negative review in the Amazon link, mine rounded off the corners like looking through a rifle scope. I'd really like to have a little longer focal length main lens on the Vision, both to reduce distortion and take pictures from a little farther from the subject. Some of the videos I've seen of kids trying to grab a quad out of the air look pretty scary. Shooting from a little higher up would be safer. I understand that longer focal length would have shallower depth of field and the vibration blur would show up more, but would like to have the option.
I have three videos on my Ben7seven7 YouTube channel currently showing the Phantom 2 vision with the 1080p 30 FPS 90 degree angle view. It's not 100% perfect but there is little to no obvious lens distortion, especially as compared to people filming video on wide. Here is a link to one of them.
http://youtube.com/watch?v=tpaYVU5JTio
Interesting, thanks Ben. As you say, very little lens distortion. It also seems to handle stabilization software much better without the curved horizon causing the banana bounce you get on stabilized vids with the wider FOV.
Even with that, though, there's something a bit more dramatic about the wide FOV, a bit more "epic" especially when you get up good and high. Still, I guess we're very lucky in that we can change those settings on the fly, so on calmer days in atti mode you can get dramatic wide FOV video with limited wobble.
I'm going to experiment a bit more with the FOV on my next sortie - thanks again!
Thanks for the info. I'm going to try this on my next flight. When my last video was "corrected" there was considerable "banana bounce." Enough to make you dizzy.
Thanks again...
-slinger
Thank you all for the valuable suggestions. It took almost an hour to do the rendering. It was just a test because it was my first flight. The rendering looks great without curves.
Firestat said:
Very nice video in Queens. But I am confused: How do you shoot at "90 degrees"? Not sure what that means.
Thanks
Chuck
Thanks, glad you like the video, feel free to check the others out. I could give links if needed. And the field of view is selected to the right of your resolution setting.
I was able to get the photoshop lens correction for my video. It definitely takes some time to render, but I'm cutting down my footage first, and only lens correcting the clips that I'm going to use which is a huge time saver.
What I'm not sure is, what export settings should I use within photoshop for exporting basic 720 and 1080 video shot at 30fps? I'm unfamiliar with DXF format?
I'm editing primarily with Final Cut Pro (can't use .mp4)
I think you meant to type DPX, not DXF (that would be an AutoCAD file). DPX = Digital Picture eXchange, a standardized format used to submit footage to professional Hollywood production & special-effect companies. Probably not something most of us would ever use.
If you're going to do further video editing & processing on this footage, you'll get the best quality renders if you choose QuickTime->Uncompressed. This will result in huge files but you won't lose video quality at each intermediate step. Ideally, only the final version should be compressed into H.264/MP4.
How will shooting at 90 degrees change that? And you would have to be horizontal to your subject to capture it that way. What if you want shots looking downward? I guess I don't understand something here.
Is After Effects a free download App?
Scav8tor
