DJI Go App - Gimbal Slider on screen indicator
On the right hand side of the screen in the DJI Go App there is a slider type gauge that shows the vertical position of the gimbal. When my gimbal is as high as it goes there is still room on the top of the slider. Is this normal?
Thanks!
Yes, it's normal. You can enable it to go higher via an app setting. It defaults to level since higher will easily show your props.
yes default is zero, each tic-mark is 10 with bottom being -90. At zero you'll have 3 more left and you can change it here .
