Distance between motors
Italy
Today while doing the periodic maintenance i noticed that one motor was not centered in the hole of the plastic cover and looks a little bit inclined compared to the others. So i decided to measure the distance from motor to motor from the center of the propellers screw and i see that for that motor is not the same as the others. Could please someone measure distance between motors from the top center of the propellers screw of his phantom 2 vision plus v3 and check if it's the same on all 4 sides (4 measure from motor to motor, a ruler is enough)? Thanks
Motor to motor around perimeter is 9-3/4". Diagonally it is 13-7/8". Motors all look centered to me. P2+ v3.
Reactions: StevenQX
I measure 249 millimiters for the two front motors and for the two rear motors. Instead, from the front to the rear motor I've 247mm on both sides. But are not centered in the hole of the cover (1motor mostly).
Ive to convert from inches to millimiters. Thanks
Jerry P
