Default gains for vision+ ?
Brooklyn, NY
So I have an FC40 and just go vision props for it.
I've noticed that it seems to over compensate for wind and videos from the gopro definitely seem a bit more shaky - especially when hovering.
I did a 2 video test.
Started a recording with the vision props then stopped it after 5 min.
switched to my standard props - started and stopped the recording.
There is definitely a difference. So I'm guessing it's the gains values.
Since the vision+ closely resembles my setup (fc40, gimbal, gopro), im thinking the gains for the vision might be what I need.
Can anyone tell me those default values?
Like this? :cool:
Negative on your pic. When he said climb I believe he meant "vertical".
A crash course on gains - the first 4 #s pitch/roll/yaw & vertical = settings to how the aircraft reacts to conditions (IE: wind, etc)
the "atti" gains - pitch/roll = how the aircraft reacts to your stick movements. If you want a sharp left/right movement you up the "atti-roll" gain.
Your best bet is load the defaults to your model Phantom then up or lower gains by 10% at a time to your liking. There's no perfect setting - each Phantom has it's own signature and each pilot has their own personal prefs type of flying.
Nice explanation, EMCS. Thanks!
