I would not make a permanent job of it - just in case need to open shell.
Nigel
If I go around with the tape it's going to cover several motor heat vent slots.I think its a universal problem .... they just start lifting at the ends.
I just added like another - a strip of clear tape ... but mine passes completely round.
Funny - when my P3P came back from DJI - the stickers were missing from the AC ... but they gave me a complete new set to apply myself.
Nigel
Does it work out that if you have custom decals and send it in for repairs, you get the same drone back?
PLUS 1 for this 100% correct you do not want to use acetone on plastic it wont end well. I had the same issue with my decals I cleaned the reses they sit in with an alcohol swatch installed the new decals and warmed them up with a hair dryer while constantly smoothing them down they are stuck like I crazy glued them now.Don't use acetone! I use acetone to vapor bath my 3D printed parts, its job is to essentially melt the plastic... not good when it comes to your shell. As others indicated make sure the surface is clean using rubbing alcohol, I've applied a few thousand vinyl decals in my life![]()
