DBS itelite Mod
To be fair I blame Amazon for the confusion.. I was unaware REX had a website of their own at the time.
I was contacted after reaching out and told that those pictures were old and that bracket is no longer available. Which sucks cause it was sunhans specific. The new one is made for the exact fit of their boosters but will still work with sunhans just not going to look as fitted.
So it was either send it back, or modify it.. I went with modify [emoji41] just removed the metal bar and took it to my friends Mr.torch and Mr.vice.
Also rocking my DBS upside down.. this brought it lower and closer to the controller. Bent the bracket to desired angle and wah lah!
Boosters and battery are in the mail [emoji108]
Apologies for the hijack, perhaps I'll make a thread when I'm done. I just wanted to share the progress so far on the REXUAV bracket. Starting to look like something..
Decided to put the two 2.4g on the outside and made a little platform for the 5.8g above the battery compartment of the bracket. This space is normally open.
I can use my existing cables to connect to the boosters. [emoji108]
Should work out well.. ordered my amp to antenna cables and battery tonight [emoji41]
By the way, SMA Cables & Adapters for Antennas [emoji118] great quality sma cable/ adapter selection.
My DBS with the Argtek antenna mount....
Yeh sorta done similar to 805hd , tacked another steel handle onto exisiting one so my panel not touch nothing,dedicated for p4 only,that why i fixed solid,hassel taking on and off
Reactions: epicdoom
I like it I have a 3D printer been thinking about making a bracket to hold boosters on for my DBS on the P34K
You technically only need two amplifiers, I've noticed some guys run three and others only run two. It comes down to money and space.
I'm going with one of these for the 2.4g
Look at this on eBay Sunhans SH-2500 2.5W 34dBm 802.11b/g/n 2.4G Wireless Indoor WiFi Signal Booster | eBay
And one of these for the 5.8g
Look at this on eBay Sunhans SH58Gi2000 Indoor 2W 5.8G WiFi Booster Repeater Wireless Amplifier | eBay
Two of these
Sunhans DC Power Adapter Amazon.com: Sunhans DC Power Adapter: Computers & Accessories
One of these
DC 12680 6800mAh DC 12V Super Lithium Polymer Battery Pack Amazon.com : DC 12680 6800mAh DC 12V Super Lithium Polymer Battery Pack : Camera & Photo
As far as mounting goes, it's up to you but I think I'm going to go this route.
DJI Sunhans eSun RC Booster Battery Bracket Amazon.com: DJI Sunhans eSun RC Booster Battery Bracket: Computers & Accessories
Or something like it. Not needed and a lot of guys mount right to the controller or make their own bracket. Once you figure out where you are going to mount everything you will know what length cables you will need.
Again I have zero experience with amplifiers but I've been doing some research around here and this seems to be the recommended setup.
Prices vary, do some shopping!
Hope this helps!
I sell the amp holders
hcashmore11
