Dashware 1.7.37 w/ Windows 10?
Is anyone successfully using Dashware V1.7.37 (latest version) under a Windows 10 build at or beyond the "Anniversary Edition" ? There's a lot of chatter out there that the Windows 10 "Anniversary Edition" update that came out mid 2016 broke Dashware's ability to render a preview of a MP4 video file. Just trying to determine if it's broken for everyone using that version of Windows 10.
Just confirmed Dashware V1.7.37 DOES run on Windows 10 Version 1511 ... this is a Windows Build prior to the "Anniversary Edition" I reference above. Also can confirm Dashware can "consume" 4K UHD video files but it cannot create or render 4K video output. When using a 4K video input file, if you select a lower resolution manually when creating the output video it will work. Tested 1280 X 720 video output successfully. Will be testing other resolutions to determine the upper limit.
12/18/16 - Have successfully tested up to 1920 X 1080 resolution output.
I had the same problem the only I managed to work around this was to create a Virtual Windows 7 Pro on my Windows 10 PC, install Dashware in the Virtual Machine created the file there and then copied to the Windows 10 desktop.
Hope this helps.
Bob
Jerry P
