Hi NikonWith no filter it is the same. Using the factory card of the P3. It is also the same when I shooting 1080p 30fps. Only 1080p 60fps is working for me for a smooth video.
Remember try to keep your shutter speed twice that of your frame rate or close to it..Hi dataway,
Just got mine in Canada. Can't wait to try it out. Thanks again.
from my post in this thread #193 I updated that there really was no difference...What's the difference in the tiffen gel?
Ok, one other test. try some video at 4K. @1/50 ISO 100. No filter.. Even if it's too light. See if it happens. I am suspect that DJI sent these cards with data rates for 1080P. I could be wrong, but look at the specs of the card they send. Here's a review. http://www.legitreviews.com/lexar-microsdhc-uhs-i-633x-16gb-card-review_134645
Note that the write speed isn't the same as read speed and where the card did ok on gopros at 1080P.
When I switched to Sandisk Extreme pro (which is what I shot the video I posted) I didn't see any lagginess. Could be the factory card they send. I could be wrong.
Here's another that concluded write speed was half it's read speed
http://thepcenthusiast.com/lexar-633x-64gb-microsd-review/
I believe you need at least 30 Megabytes per second minimum sustained write speed for 4K. Might try benching your card to make sure it's doing what it should do.
I tried on this bright day with 4k 24 fps, 1/100 sec. with the two ND filters attached (so 6 stops).
It's not so smooth as I expected. Do I something wrong or? My PC can handle 4K, so that's not the problem. I tried different players (VLC, GOM Player, Windows Media Player).
When I downscaled to 1080p 24fps, it is not smooth enough either.
I guess I will stick with 1080p 60fps to get the smoothest video. Let me know what's your opinion...
I'm a little disappointed in the P3P video smoothness.
I must have some settings not quite right or something. Call me crazy but I think my videos before the filters were sharper with less grain and flicker. Any ideas what I might be doing wrong?
With 2 filters iso 100 1/50 4k 30fps
No filters and no post processing
