CS issue
Ive had a CS Ultra bright for a few days.. everything has been ok. today when using it I see in the display in the lower right corner the map where you can toggle back and forth between the camera view and map view. Now the map view is just a grid with chinese writing and smiley face. You can see the arrow. I must have hit some sort of setting by error. Same with 2 different mavics and 2 different controllers. My ipad works fine so definitely something with the CS
might try a software reset on CS? I believe it's under the main settings, but it will return the CS to factory specs.
Paul C
