CREE light holders
Palm Beach County, FL
Can give link to the Lights?
The Strobe Lights themselves he has shown can be purchased from Firehouse Technology. However, I would recommend the ARC II over the single Cree or Dual Cree, they are way brighter.
In the photo below the strobe on the right is the ARC II, it has 4 LED's and it is blinding, the one on the left is the ARC Tri-Color (flashes Red, Green, White).
Yes the ARC series looks nice. I’ve had the single and duals before the ARC was released so I haven’t had a chance to use them. Looks like the ARC size is a tad bit larger than the single and dual lights.
Does it flash all 3 colors at the same time or does it do red, green, white seperately?
Yes the ARC and ARC II are a bit bigger, but well worth it especially on the Phantom series as you have plenty of mounting area to work with.
Below is a comparison in size from Left to Right: Firehouse Technology ARC II, Flytron Standalone, Strobon Cree (similar in size to the Firehouse Cree).
Reactions: Tarheelldo
The Tri-Color ARC flashes alternating RED then GREEN then WHITE. The ARC II with the 4 LED's flashes all 4 at the same time for the extra brightness, all 4 LED's are the same color.
Reactions: PhantomHero
Words can’t even explain how bright the ARC II shines. Mine just came in today and it’s amazing.
NOTE: Leave the plastic shrink wrap around the battery and board ON.
MS60
