Crash! Phantom 2 vision plus.
ARM
Crashed into bridge pipe, phantom went down in wet sand, and small splash of water all over camera area, no water inside. took care of that. Put battery in phantom and normal chime of start up , then a constant beep beep beep beep sound. left front motor does not turn, right rear motor kind of slow to respond sometimes jerky. it will calibrate doing the compass cal. ANY IDEAS WELCOME
the constant beep is what I'm worried about, i can replace motors i have some. need ideas for the constant beep. advanced calibration and basic calibration all are good
the constant beep is the NAZA moaning about something, dont suppose you have hooked it up to the PC and had a look at the software.
