Hi
Just tried my first couple of flights (crashes cough!) Two things. When it takes off it seems to lean downwards to the front so you need to increase the upward thrust straightaway to get it off the ground. When hovering it tends to turn towards the left direction and the nose of the craft always tended to go towards the left. So ended up using the yawl to correct this but it wanted to veer again. Couple of small crashes as I have not had the craft much more than 10 feet or so off the ground. The last crash was into me but grabbed the craft and shut down! One prop is chipped at the end, the others just grass strained. Replaced chipped blade- can it be smoothed down again or best discarded? Only done a compass calibration so far- nothing in the software. No error codes- GPS mode no wind.
Any suggestions?
cheers
Any suggestions?
cheers
