That's what I wondered are all the problems mainly with the ultra high bright and or the 7.8 or is it just the ultra bright?Ive been using the 5.5in model for several months now with no issues in high heat, is this typically with the 7.85in model?
It seems that way using the UltraBriteIve been using the 5.5in model for several months now with no issues in high heat, is this typically with the 7.85in model?
Yeah I was told they corrected the problemI have the 7.85" Ultrabright model. And if you Google the problem, there is a disturbing number of discussions about this and overheating problems. Apparently, when it gets into the 80s, the panel works for about 5 minutes and then shuts down with an overheat message.
I'm in a bit of a quandry, because I cannot fly in the daytime without it, and using my reliable phone would limit me to flying at dusk or at night when I can see the screen.
Maybe somewhere there's a list of serial numbers of the ones that have been fixed.Yeah I was told they corrected the problem
Somebody's got to have a phone number for the manufacturer maybe they can give up the information.That list would be handy. Else how do we know if we got one of the bad designed units?
Yeah well I received a freshly restocked one from a retailer so you would think its OK but it wasn't. Just buy one from a retaler with a good return policy just in case you need itMaybe somewhere there's a list of serial numbers of the ones that have been fixed.
In other words from a specific serial number and higher the problem has been fixed.
It not working is a good sign LOLThat list would be handy. Else how do we know if we got one of the bad designed units?
I sent the Ultra back because of problems and I've only flew with the HB for 6 flights but its also a little buggy at start up needing a reboot, but its still early to form an opinionIs anybody having problems with the 7.85 high brightness not the ultra?
Thank you for the honest review, it's much appreciated, I had no idea there was this many issues with CS, and I would have expected DJI to offer better support for it.
My high brightness CS has been behaving fairly well over the past few months with my P4 Pro. This weekend, I plan to test how it handles 95°F+ Summer heat in direct sun.
Would you be willing to to try a little test , press the RTH button on one of your flights and then check the flight record if it records the entire flight before and after you entered RTH
