Clip longer than five minutes
Yuma AZ & Nevada City CA
Yesterday I shot a steady fourteen minutes, never gone that long without a cut. Surprised to see that I ended up with three clips of no longer than five minutes each. When I tried to stitch together in GO4 I got a message that I can't do this due to some inherent limitation on what can be uploaded.
OK I get that, can't submit anything more than five minutes. But why can't I record something longer? I can always edit on my desktop and not worry about the GO4 editor. Is there a setting to avoid unwanted cuts in my video?
I use Adobe Premier to stitch them together. At the end, it runs smoothly and you won't know they were divided into files.
Yesterday I shot a steady fourteen minutes, never gone that long without a cut. Surprised to see that I ended up with three clips of no longer than five minutes each. But why can't I record something longer?
Perhaps you reached the ~4GB file limit and the Phantom split your video as you were recording it. In your case two splits to create three files of ~4GB or less?
Reactions: JoBe
The question is not how long clip (record time) can be recorded, but how big file (data size) can be recorded. As Oso said approx. 4GB/file.
Reactions: JoBe and Oso
Agreed - Oso is correct.
The Fat32 format limits all files to 4Gb max size segments.
Regardless of formatting as either FAT32 or exFAT, the Phantom will still split video files at ~4GB even though the exFat format itself allows larger files.
That is of course unless something has changed with the Phantom finally after several years of having a 4GB limit.
Reactions: JoBe and Eagle54
hcashmore11
