Christmas Present
Hi, bought this drone for my kid. We were able to do the firmware update. Problem is when I turn on the remote and the drone, the camera shakes and makes a loud vibration noise that won't stop. I removed the protective shipping sleeve and the lens cap. Still vibrates with the loud noise. Any suggestions? The only thing we didn't do was attach the propellers because we were going to do the flight sim.
Thanks,
I believe there is also a little piece of styrofoam up by the camera. Check and see.
Seems to me when I got mine the was a white piece of Styrofoam about the camera. I could be wrong.
The little foam.
No one has mentioned which MODEL of Phantom that you have.
From other threads, I've read that that the Phantom 3 Standard does not come with the foam.
Screw that requires tightening after first opening? That's a new one to me.
It's normally not loose out of the box.
FYI, here's an example showing what happens when the grub screw is loose:
Reactions: Joe Broadway
intertronixlabel
