Charging P4P Controller
Which P4 charging station are you referring to?
The DJI battery charging hub is powered by the battery charger that came in the box with your Phantom. You can charge your remote controller with the cable connected to that battery charger (see below). It's okay to charge the Phantom batteries and your remote controller at the same time.
Yes. Both can use the same charger/hub.
Thanks. I had to order a P4P controller to replace my defective P4 controller. It has been suggested that I reload the P3 software to correct the charging problem in the P4. Any suggestions on how to do this.
Have you made sure the P4P controller is compatible with the P4, as an experiment I've had trouble linking it to my P4 given the current P4P controller firmware ?
I was able to link it to my P4. Took a couple of trys, but it works. It flew very well today.
