Changing Video Bitrate
Hi, Is it possible to change the video bitrate on the Phantom 2 Vision+?
Now the bitrate is 12 Mbps - I could increase it more?
dont think so.
also i think that 1080p@30fps is crappy as there is a lot of dropped frames making the whole video inconsistent.
im recording at 720p@60fps which is super smooth and no dropped frames.
z10m said:
dont think so.
Really, you shouldn't have dropped frames. Even at 1080. You should check your SD card. I have a smooth 1920X1080 at 50fps from my go pro. I use a micro SDHC Sandisk extreme 32GB, class 10 45 mbps.
I have not checked but what class is the card that comes with the camera ?
I do have a 32gb card, class 10 if need be.
I'm talking about camera of Phantom 2 Vision + not GoPro i know that GoPro records perfect videos.
Card that comes with P2V+ is class 4 and it gives me about 5MB/s write speed.
I'm using class 10 card with write speed of about 15MB/s and video is exactly the same
Thank you all for the answers
From what I understand
To get the best quality video, I need to set the camera at 720p/60fps. what about the FPV mode? what recommended for smooth picture quality?
720p/60fps is my personal preference you might like 1080p/30 or 25fps more you need to find out yourself.
In FPV mode I'm using 320x240/30fps as 640x480 doesnt work well for me at all.
Reactions: Mako79
I agreed and I use 720p/60fps for video to get smooth recording.
For FPV, I'm using 320x240/30fps and sometimes down to 15fps, depending how far and high I'm flying. But I don't use my P2V+ to fly FPV much! I prefer my 250 mini or my Flamewheel F450....or my Blacksheep!...and the list goes on and on....
dont think so.
I use the 16g mini sd card samsung pro. Smooth shots, no dropped frames.
Any of the class 10 D's cards can handle the frame rates and transfer speeds. That's what's recommended.
+1000
1080p @ 30fps has too much compression and therefor too much artefacts - the bitrate can never be changed as this is the limitation of the camera.
720p @ 60fps is the best.
FPV should be 640x480@15fps minimum if you want see what you are framing in your shots.
I did 2 birdside hacks to get 640x480@30fps for >500m range:
- Wifi module Artic Silver 5 thermal re-paste, preventative overheat/failure mod which makes the module run cooler and more effectively.
- $10 DBS wifi antenna re-allocation hack, take the wifi antenna located inside the battery slot and externally mount them front and rear.
seocompanycalct
