Geert said:dave21 said:Hey guys I made my 7th channel work on 3.04fw. Connect your bird to the hack sw. Open the settings in the mobile app and DISABLE the FPV MODE. If it's off just toggle it on and off. Activate the hack. It remains active after power cycle. Yupee I can use my lever again and have the waypoint feature. Let me know how it works for you.
Edit: premature happiness. When disconnected from sw it looks dissapear again :-(
Yes, exactly. I made the same mistake too. :lol:
This also happened with previous firmware version. Guess it will only work on 1.08.
But Dronexpert offers a solution : http://dronexpert.nl/product/pre-order- ... no-slider/
Geert./.
Geert said:ResevorDG said:Dronexpert.nl has a solution now but it is expensive.
PFV Booster is working on an app that will do the trick.
Here is a conversation about it. He mentions it about 6 posts down. viewtopic.php?f=27&t=13496&p=185802#p185802
PFV is working on it, you sure ?
I know he wrote that also 5 weeks ago in another topic. I doubt his words.
Agree, the Dronexpert solution is expensive.
Still hoping that DJI is coming up with something.
Geert./.
ResevorDG said:Geert said:dave21 said:Hey guys I made my 7th channel work on 3.04fw. Connect your bird to the hack sw. Open the settings in the mobile app and DISABLE the FPV MODE. If it's off just toggle it on and off. Activate the hack. It remains active after power cycle. Yupee I can use my lever again and have the waypoint feature. Let me know how it works for you.
Geert./.
Geert said:For some reason DJI don't want us to use the lever at the backside. I did send several emails to DJI but no response so far.
I seriously doubt the app developers can work around this issue, but you never know if and when the white rabbit will come out of the hat.
:lol:
Geert./.
Have you upgraded to the latest firmware 3.06? Wondering if the functionality could be affected by the firmware.pyrophantom said:Still enjoying my DE lever function![]()
Cool. Easy enough for me then. I'm hopeless with soldering and stuff like that.pyrophantom said:There are instructions in a video but its easy peasy to do, just a bit of unplugging and replugging new cables and put it back together, no soldering or anything.
imelda1804 said:Is it working on 3.04 or 3.06? Or both?pyrophantom said:Still working !!
