ce/fcc with p2 2.4g
I see everywhere ppl talking about changing to fcc on the 5.8. Can you do the same on the 2.4g tx?
Thanks for any insight fellas
Jeeperak
As far as I'm aware, the 2.4Ghz transmitter on the Phantom 2 does not have a CE / FCC mode switch.
The P2 Vision Rc controller beeps when you turn it on to indicate what mode it's in. The P2 transmitter doesn't beep.
Legal limit in the US is 1,000 mW effective radiated power on 2.4Ghz. In the UK the limit is 100mW.
I've no ideas what the output power on the P2 transmitter is, maybe someone has tested it ?
DJI wiki says:
http://wiki.dji.com/en/index.php/Phanto ... RANSMITTER
Nothing on the P2 output power though... maybe it doesn't comply ?
Edit: did find this confusing info though:
http://wiki.dji.com/en/index.php/Phanto ... 8D11.1V.29
"Power Consumption of TX: <20dBm" - power consumption? measured in dBm ? hmm..
Looks like it would be around 100mW
thank you sir very much. i was figuring this was the case but, i am wrong quite often.
jeetbuzz360
