Looking to get a case for my standard... Any recommendations? Pictures/ links.. Will spend up to £150ish... Thanks.
Not so.I just received the same case as dpicx68, First impressions it appears quite good, inside looks the same as the DJI backpack, Not a lot of room for other stuff, but i can get everything in including the charger and my 8.4" tablet. Standard fits well, but if you have the Inspire 1 device holder, you will have to remove it to get the controller to fit. The device holder will sit nicely next to the bird.
Went for this on..
The CasePro Phantom 3 Carry On Case is one of the best drone cases on the market. It can hold all of the phantom 3 series drones and you can keep your props on with it stowed. It is a hard core SKB case so you know it's strong. I use mine for the Phantom 3 Professional and it works great. It can hold up to 5 batteries, the charger, extra props, and even comes with a small tool case for filters and sd cards. It is a great travel case too because it can fit in the overhead on a plane so you don't have to check your drone and carry the batteries on separate. You can find this case hereLooking to get a case for my standard... Any recommendations? Pictures/ links.. Will spend up to £150ish... Thanks.
